Need a diagram to wire up plx gen 4 to kpro
Moe1786
Post by Moe1786 »
Hi guys i need a diagram to wire up my plx device to my kpro my ecu is a pra please help
Re: Need a diagram to wire up plx gen 4 to kpro
http://www.hondata.com/help/kmanager/an ... b=wideband
The version 3 and 4 are wired the same way.
Moe1786
Post by Moe1786 »
So the ground wire from the plx unit must be connected to the ground on the hondata and not ground it on the body?
The plx should just use a chassis ground. There is no signal ground needed.
Moe1786
Post by Moe1786 »
Thank you so much
Moe1786
Spluttering issue
Post by Moe1786 »
Hi Sir
My name is Muhammad, im from South Africa, ive got a ek civic with a k20a2 motor and kpro, im having issues with a misfire at high rpm, ive changed coil packs,plugs,injectors,fuel pump,map sensor,crank sensor added extra earths and a relay to the ecu im using ngk bkr7eix plugs my engine is almost standard i dont know what else to do to solve the problem, would it be possible for me to send a log and get some assistance?
Regards
Please start a separate thread for this and include calibration as well as datalogs showing the issue.
Moe1786
Post by Moe1786 »
I don't know how to create a new post or upload a log but I can email a log and calibration
