FlashProManager V3.1.1
typer86
Post by typer86 »
URGENT:
Again the AFM.Fuel timing bug comes up again on RSP based ECU in the latest beta.
In MAP fuel tables all working fine....
The car runs really rich. I will send affected tune + datalog via email to you to avoid calibration steal.
R-12914
Re: FlashProManager V3.1.1
Post by R-12914 »
Hondata, do you have fixed this problem on the FN2?
2008 Honda Civic TypeR FN2
ECU: 37820-RSP-E02
Flashpro: FP-SI-INT-21153
Software: 3.6.1.0
Firmware: 185
What exactly is the problem you are having? What version were you last using before the problem? What version are you using now?
R-12914
Post by R-12914 »
Hondata wrote: Fri Aug 03, 2018 2:10 pm What exactly is the problem you are having? What version were you last using before the problem? What version are you using now?
Now, im using the 3.1.1.0 since 15. July 2018 and the AFM-XY-Graph is very rich @ round about -15, look here:
With the old Version (i remember/think 3.0.9) the AFM-XY-Graph was on -3.
This error was once before there some time ago in connection with the FN2!
Thanks for fixing this issue again and I hope that this mistake will never happen again!
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
R-12914
Post by R-12914 »
Hondata, what is going on, now?
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
I've checked for the same problem as last year and that is not it.
I did find the ethanol content fuel compensation table has the wrong conversion. This will not affect the fuel as long as you leave the values as they are (-80% range). I have fixed that for the next release.
R-12914
Post by R-12914 »
Hondata wrote: Mon Aug 06, 2018 1:21 pm I've checked for the same problem as last year and that is not it.
First, thank you for your answer!
I did not changed anythink between the old version and the new version of Flashpro Manager.
I don't run ethanol fuel and i did not changed anythink of the ethanol content fuel compensation table.
What do you have fixed for the next release?
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
Tested here and it ran the same as last year. If you are sure of the versions (3.0.9 vs 3.1.1) then I can test the difference.
R-12914
Post by R-12914 »
Hondata wrote: Mon Aug 06, 2018 4:48 pm Tested here and it ran the same as last year. If you are sure of the versions (3.0.9 vs 3.1.1) then I can test the difference.
Yes, 3.0.9 vs. 3.1.1!
Please test it!
Thanks!
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
Tested 3.0.9 and 3.1.1 back to back and they are the same.
Are you sure about the mode (AFM vs MAP)? And the versions?
R-12914
Post by R-12914 »
Hondata wrote: Tue Aug 07, 2018 2:21 pm Tested 3.0.9 and 3.1.1 back to back and they are the same.
Ok,
try conparsion of 3.1.1 vs. 3.0.8, 3.0.7 and 3.0.6 also with the 64 bit version of Flashpro Manager.
The problems are only occurred in connection with the FN2, which you do not have to test!
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
I have tested the FN2 ECU in a vehicle. Will test back further.
R-12914
Post by R-12914 »
OK, I'm curious!
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
typer86
Post by typer86 »
Hondata wrote: Wed Aug 08, 2018 7:36 am I have tested the FN2 ECU in a vehicle. Will test back further..
So you can also test the feature "ANTI LAG".
If I am right, this feature does not work in our ECU currently.
Ok, in testing I found no differences between V3.0.1 and V3.1.1. The last change I made for the FN2 was V2.9.2, so that makes sense.
