Smanager gives extra fuel when throttle is rapidly opened
danielsvenningsen
Post by danielsvenningsen »
Hello Guys.
I am looking in to some problems, in smanager we have the "Throttle tip in trim", and that is good in the low RPM, but if it gets over 5-6000 RPM, it tip in way to much fuel.
I have tried put in 0%, but then it still puts in extra fuel in the high RPM, when the gas is rapidly opened.
Does anyone have a clue on where and if you can set the extra fuel somewhere else for the throttle ?
Attach is the injector signal, and in the middle i tried pump the gas very fast, and it put in WAY TO MÙCH fuel. but only if it fast from 0% throttle to 100%.
Kinds of
Daniel Svenningsen
Re: Smanager gives extra fuel when throttle is rapidly opened
The AF reading in the datalog is not changing. Do you have a wideband?
