Strain Gauge From Flatshifter
Steeve_Civic
Post by Steeve_Civic »
Hi,
I have this Flatshifter and would like to ask how to configure it please on S300.
https://www.flatshifter.com/flatshifter ... gear-knob/
I have a 2,5V Amplifier module and 4 wires.
+ Battery
- Ground
Red wire for Upshift
Blue for Downshift
Flatshifter answer below:
As you have a H pattern dog box you will need an ignition cut in both
directions so will need to connect both red and blue wires to the ignition
cut pin on you ecu.
Thank you for your help.
Re: Strain Gauge From Flatshifter
I'm not sure if that will work with the s300 or not, but you can try.
Details on setting this up are in the help file: http://www.hondata.com/help/smanager/fu ... l+throttle
Steeve_Civic
Than you Spunkster
So I need to connect both wires (blue and red) to one anolog wire Input of S300?
Then configure it in Voltage?
Thks
You can try it and see how it works.
Steeve_Civic
It seems working.
SCS sensor jump to ON when I shift, It switches to ground.
at idle it is a very little cut, Around which duration is good?
You will have to try different settings to see what works best for you.
Carpart999
Post by Carpart999 »
What setting in hondata to make it work?
Carpart999
Can you post settings in hondata? I have the same strain gauge flatshifter strain gauge tks
