ARF WOT FOR E85 FUEL
FlashPro questions & answers specific to the 2010 CR-Z (US, Euro & Asia)
Kevin1166
Post by Kevin1166 »
Hello
Mycar is CRZ 2011 JP CVT
Currently using E85 fuel.
I have changed the injector to 310cc.
I want to know how much I should use AFR WOT ?
for E85 fuel to get the best results.
Thank You
Re: ARF WOT FOR E85 FUEL
WOT start point on e85
if na start at 12.5afr .85lambda
if forced induction start at 11.5afr .78lamba
Kevin1166
Post by Kevin1166 »
Spunkster wrote: Tue Aug 21, 2018 5:18 pm WOT start point on e85
Thank you for your suggestion
How many we should increase the degree of ignition for E85 fuel.(from base map Calibration)
You should only adjust the ignition on the dyno so you can measure the power changes.
