1.5 civic flashpro query
Civic 2016+ 1.5 Turbo
JackHowes
Post by JackHowes »
Hi all,
I have the 1.5 civic sport plus in the uk. I run the +6PSI map, I was wondering if it was possible to put the +9 map on ECON mode, so that If i pressed ECON mode or another button it would switch to plus 9, without having to flash the entire ecu every time. That way I can switch whilst travelling.
Re: 1.5 civic flashpro query
You can change the torque tables to allow more or less torque in either mode. This will allow you to use the different modes to achieve different power levels. You will find though that there is very little need to use a lower power level.
JackHowes
Post by JackHowes »
Great, how do I adjust the tables? Is there a video tutorial? I run the +6, but still want a little more torque without going into the +9 and knackering my clutch
