2009 TSX CT SC Tune and Injectors
DL1000Doug
Post by DL1000Doug »
Hello. I just almost installed my SC (almost installed that is), but when I got to the fuel injectors they did not seem to fit quite right. I noticed the tune on the FlashPro is calling for 780cc injectors, but the DW injectors box is marked as 550cc. Something may be off a little since the instructions say to use the stock retaining clips on the injectors, but they don't seem to fit or retain the injectors in the rail. Are these 550cc injectors modified to 780cc? Seems like a big jump over stock for somewhat modest boost. If the 550cc injectors are correct, is there a starting tune for them?
Re: 2009 TSX CT SC Tune and Injectors
You should discuss this with whoever sold you the kit/injectors.
DL1000Doug
Well, the injectors were shipped from CT Engineering as part of the SC kit. I have a call into CT, but they have not called me back yet.
