JDM DC5 Type R w/ USDM PND ECU
jackyft
Post by jackyft »
Dear All,
I have a question that if I have a USDM ECU 32820-PND-A07, is it possible to install to a JDM Integra DC5 Type R w/ K-Pro V4? I do some research it need to swap cable between E1 and E10 for fuel pump. Is it true?
Thanks in advance.
Jacky
Re: JDM DC5 Type R w/ USDM PND ECU
You do not need to make any changes for the fuel pump. You will also not have reverse lockout for the 6 speed transmission, unless you wire the reverse lock-out to the secondary runner output on the PND ECU.
