AIM Solo2 DL - CANBus
AngryScottish
Post by AngryScottish »
I have a KPro V4 exporting CAN data to an Aim Solo2 DL.
I have the Digital Output set to AIM MXL
I have the CAN Output set to MoTeC SDL/ADL
I have PLX sensor data being set to the digital inputs, as described here: https://www.hondata.com/help/kmanager/i ... inputs.htm
I have all of these channels available within the Aim Solo2 DL: https://www.hondata.com/help/kmanager/i ... inputs.htm
In KPro datalogs, I can see all the channels that are exported on the CAN Bus (as I should) and the Digital Inputs being sent by the PLX sensors.
BUT, I cannot see the PLX sensor data in my Aim Solo2 DL... is there a way to view this on the Solo2 DL? Are the digital inputs even being sent to the CANBus (not sure if they would or not)?
CN/Summary:
I want to see my PLX sensor data that is being sent to the digital input on my KPro, on my Aim Solo2 DL, via the ECU connection to the Solo2.
Re: AIM Solo2 DL - CANBus
It can only send the data for the analog inputs on the K-Pro.
http://www.hondata.com/help/kmanager/can_output.htm
