Red box green box
Awsomsauce
Red box green box
Post by Awsomsauce »
When you make adjustments to various tables why will there be a red box or a green box around the change made?
Re: Red box green box
What specifically are you referring to?
Awsomsauce
On the flashpro in the tc maximum pressures, I change some levels and other levels around it or the square itself high lites red while others are green
It just shows if you have increased or decreased the values.
Awsomsauce
Okay thank you 🙏🏼
