Car won't Idle, Built lsvtec turbo, basemap attached
BoostAddict1488
Post by BoostAddict1488 »
Car won't idle after setting up a basemap. Can anyone review this for me? If I hold throttle when starting it will idle. However, very rough and extremely rich, wideband showing 8.06. Thanks in advance.
9.1 cp pistons on manley rods
full bolt on
skunk 2 im and 70mm tb
garrett gt30
4 bar map
fic 1000
gsr head, itr cams
58psi base fuel pressure
rewired walbro 450 high pressure, with 6an feed and return
Re: Car won't Idle, Built lsvtec turbo, basemap attached
Have you tried removing fuel to see if you can get it leaner?
BoostAddict1488
I messed with it some after work last night. Tried pulling -5, then -10 and saw nothing change. Made it all the way to -35% and nothing changed, so quit pulling fuel on it.
As this sounds like a tuning issue, I would suggest talking to your tuner about this issue and see if they can give you a better basemap to start from.
BoostAddict1488
Great....... definitely not the news I was hoping to hear, but I will get back with him.
BoostAddict1488
Found that Hondata was not able to display battery voltage. When I changed the deadtimes to 14v, the car runs... I did notice one of the caps inside the ecu has a brown ring, where it appears bad. Does anyone know if bad caps will cause this issue, with not allowing voltage to be seen?
I would recommend that you replace the capacitors to see if that resolves the issue.
