S.Trim with Analog WideBand
terrorista
Post by terrorista »
Guys,
I need your help configuring the External O2 Wideband sersor for lambda controlling. S.trim and L. Trim.
i just wired and configured an eternal 4.2 LSU Wideband (with controller) to the pin B29.
I've configure it under FP Manager.
I've changed the Lambda Overlay parameters, checked out the primary O2 Sensor and still not working.
Thanks for your help,
Rodrigo.NovoChicote.fpcal
Re: S.Trim with Analog WideBand
You cannot run in closed loop from an after market sensor. You must use a factory wideband to do this.
