VTEC Pressure values
skaterguy1986
Post by skaterguy1986 »
Is there any way to reverse this value? I want to have it set up like the Honda HDS software, I want it to show as "ON" when on the low cam as the pressure switch is closed and "OFF" when the VTEC solenoid is "ON" as oil pressure is no longer high enough in the spool valve to close the contacts on the switch.
Thanks.
Re: VTEC Pressure values
No, there is no way to reverse this.
