AFR issues
Civic 2016+ 1.5 Turbo
Awsomsauce
AFR issues
Post by Awsomsauce »
So I’ve turned the boost up and I’m getting a fuel drop. The fuel attempts to hit the cmd fuel but it cuts back to 14 and 15 out of nowhere then comeback. At one point I was WOT, at 22 psi, the cmd was 11.53 and the AFR was 29 like I wasn’t even on the throttle. I have the tune and datalog I can send you if you want to see for yourselves
Re: AFR issues
Post the calibration and datalog showing the issue.
Awsomsauce
Re: AFR issues
okay here is the tune and the datalog of the last pass made on this tune.
I increased the target afr in one area because on the previous pass it went lean in that rpm range.
I had also switched the use map for wot to off.
Re: AFR issues
It could be that your wideband sensor is not reading correctly because it is hot or contaminated, or your DI pump could be maxing out at higher boost levels and high ethanol content.
Lilwonton17
Re: AFR issues
Post by Lilwonton17 »
Awsomsauce wrote: Thu Sep 13, 2018 8:06 pm okay here is the tune and the datalog of the last pass made on this tune.
AFR readings of 29 means the injectors turned off for a period of time. I think that is the max value that the AFR can read as far as lean goes. If you are seeing it off the gas coasting while in gear then it's not a problem. But If you are seeing it while accelerating that is a sign of fuel cut.
Awsomsauce
Re: AFR issues
Lilwonton17 wrote: Sun Sep 16, 2018 3:50 am
what could be causing a fuel cut. too much ethanol enrichments?
Awsomsauce
Re: AFR issues
**!! Update! !!**
Okay so I still kept having that miss and drop in the afr even after closing the gap from the stock from Honda plug gap of .030 to .025 which did help reduce the miss and drop but didn’t completely resolve the issue.
So I blended the fuel down. Put 4 gallons of pump 91 octane to a just over half tank of e85. Now there’s no issues.
So Hondata the questions that come to mind are, is the base tunes dumping WAY too much fuel and washing out the spark on full e85 tunes or is there something that is incorrect in the timing tables? I can’t see how reducing the ethanol content would resolve the issue I was having. The only thing that makes sense are the timing and fuel enrichment go up as you go up in ethanol content and come down as you go down.
I’d highly recommend running blended fuel for anyone that cares to read this . Either 40-55 ethanol blend.
D-Rob
Re: AFR issues
Post by D-Rob »
It's likely a misfire related to trying to hang the injector open too long.
The fuel system is too small for a significant amount of ethanol without targeting a leaner mixture.
Awsomsauce
Re: AFR issues
D-Rob wrote: Mon Sep 24, 2018 5:41 am It's likely a misfire related to trying to hang the injector open too long.
I see, thank you everyone for your input on the issue it does not get taken lightly.
