Can 02-04 PND Kpro4 works with 05-06 Type S Gearbox?
CHB
Post by CHB »
Hi Hondata,
As title, can 02-04 PND Kpro4 works with 05-06 Type S Gearbox?
I am going to upgrade the stock 5-speed gearbox to a 6-speed gearbox from 05-06 Type S. My question is how to make the speedo works?
Thanks.
Re: Can 02-04 PND Kpro4 works with 05-06 Type S Gearbox?
You can get this to work with the ECU only, but the gauge cluster will read incorrectly. You will need some kind of speed sensor adapter to change the number of pulses that the cluster receives.
CHB
Post by CHB »
So is it just the calibration file that need to be configured? under which section changes need to be made to the calibration file?
It is in the Misc. section of parameters. This will have no effect on the cluster readings.
