Change Boost via Flashpro
CRV 2017+ 1.5 turbo
Natesimon204
Post by Natesimon204 »
Stock boost is 14psi, hondata flashpro adds 6psi for a total of 20psi
How can I add 1-2 more psi, I don't want to blow the engine up, but i have heard some people change boost to 24.
Re: Change Boost via Flashpro
I would recommend against this as the CVT cannot handle the added torque safely.
Natesimon204
Then I will leave it be. Side note, Honda will be coming out with a fix for their lack of heat and oil dilution, I believe they will be reflashing the ECU. When that happens I will probably lose my flash pro modifications... Would you rerelease an update? If you need help with getting a bone stock ecu image after the fix, I can assist.
Yes, we will make an update to incorporate the changes.
