FK8 Error uploading
L_S_i
FK8 Error uploading
Post by L_S_i »
Hi, a customer brought me a car and a flashpro where the bosch ecu is jailbroken already. While uploading a calibration I got the following code and now I cant even return the ecu to stock. It happens in both upload and return to stock.
"Failure information: Code 0x4 Step 16 Address 0x340000
Explanation: The ECU stopped responding while reflashing. Check OBDII connector pins."
The flash pro was successfully locked to the ecu/car. Software is up to date and Flashpro updated its firmware when ignition was turned on for the first time.
Jun43
Re: FK8 Error uploading
Post by Jun43 »
did you try uploading the calibration with just the dongle itself and not connected to the laptop
just a temp solution to get it running maybe
What is the FlashPro serial number?
What is the ECU serial number? (should start with 95BFA)
L_S_i
Post by L_S_i »
Hi,
software is 3.1.5.0
Flashpro serial is FP-CTR-FK8-INT-370061
Ecu is 95BFE030032988
Who did the Jailbreak on this ECU?
L_S_i
Post by L_S_i »
A chiptuning company did. With magpro hardware/software. Do you think the jailbreak wasn't properly done and could cause this issue? But wouldn't flashpro software detect that the ecu is locked and prevent the upload?
With everything plugged in and the ignition on, go to the Help menu and click on send information to Hondata support. include the serial number on the FlashPro and a description of the problem.
L_S_i
Post by L_S_i »
Sent a couple hours ago. Thanks
It is because it is a E03 ECU but has a G03 calibration in it. We will send instructions via email.
L_S_i
Post by L_S_i »
Hondata wrote: Thu Sep 20, 2018 9:57 am It is because it is a E03 ECU but has a G03 calibration in it. We will send instructions via email.
Thank you for the reply. Havent got the email yet. Please let me know when its sent. Thanks again.
L_S_i
Post by L_S_i »
Hi guys. Havent got the email yet and the customer needs his car back. Its pending waiting on that email . Thanks.
We have emailed you, but your ECU has not been properly jailbroken and will have to be corrected by whoever did the jailbreak on it.
L_S_i
Post by L_S_i »
Havent got it. Can you please send it to raceandmap@gmail.com . Thanks
L_S_i
Post by L_S_i »
Sorry to persistent guys but I havent recieved the email. Can you please make sure its sent to raceandmap@gmail. Thanks.
Don't worry about the email, it is telling you what I have just said.
