U0301 - ECM/PCM mismatch
Civic 2016+ 1.5 Turbo
samuelt1995
Post by samuelt1995 »
Hi,
I recently purchase a Flashpro for my civic 2016 turbo.
I flash the computer and then a got a check engine. I looked for the code and I saw U0301 and I'm unable to erase it. I looked on the internet and I see it is a mismatch computer.
I try to flashback to stock ECU and it still showing that error code.
My ECU number is 37820-5AA-C66
I bought my car in Canada
Please help me.
Thank you,
Samuel
Re: U0301 - ECM/PCM mismatch
The error is because the ECU probably has been flashed by the Honda dealer to 2017 to match the TCM.
What calibration did you load? The 2016?
samuelt1995
Hi,
You are right. Honda had to flash my computer one day because the car rpm varies on the highway.
I first flash with the +6 psi first. Now I back to stock ECU. So you think flashing with 2017 will solve my problem. If so, how can i do it? And if I want to go back to stock ECU, how do I do that?
Thanks,
samuelt1995
Hondata wrote: Sat Sep 29, 2018 4:52 pm The error is because the ECU probably has been flashed bby the Honda dealer to 2017 to match the TCM.
I tried to use a 2017 Canada Touring one and it didn't want to flash. I tried many other, same thing.
I flashed on a 2016 one.
How can I flashed with a 2017 one?
Can you use the 'support support information to Hondata' function from the help menu (with the FlashPro plugged in)?
samuelt1995
Hello,
I did a firmware update and I was abble to flash on +6 psi 2017. All the error code is gone.
Thank you so much.
Ok, glad it is sorted out.
neodragons
Post by neodragons »
Hondata wrote: Tue Oct 02, 2018 7:08 am Ok, glad it is sorted out.
hello, i am also having this same problem. but with the recent update of hondata. its says i cant up load the 2017 or 2018 cvt tune to a 2016. please advise
neodragons
to add, i was able to do this before on 3.5 i think, but once it updateed to 3.7 it no longer let me upload the 2017 tune
Our crystal ball is broken - please some details.
neodragons
nevermind, went for a drive after uploading the base map and check engine light went away.
Ermrz99
Post by Ermrz99 »
Hello.
I am not having the same issue. 2016 1.5 T with ECU incompatibility. I tried uploading a 2017 calibration to no avail. I then tried uploading the 2016-2017 and I genuinely did not feel much power. When I was originally running the 2016 calibration I felt the power nicely however the ECU incompatibility is causing emission system problem to show up on my dash. What should I do? I don’t want to have to return it :(
