Calibration needed for PPA 02-04 CRV ECU KPROV4
Blulude98
Post by Blulude98 »
Hi all,
What calibration is compatible with a 02-04 CRV ecu PPA ecu?
When i upload the PRB, PND, PNF calibrationsof the kPro software, i keep getting errors : P1607-ECU Internal circuit Malfunction (Check calibration)
If I upload a PRA calibration i do not get this error but i also do not get any communication either.
Can anyone advise what map i can use for my PPA ecu?
p.s I get this error with x3 PPA ECU's so i do not believe the ECU is at fault.
Re: Calibration needed for PPA 02-04 CRV ECU KPROV4
You can only use a PRA calibration on a PRA ECU.
When you say no communication, do you mean uploading or datalogging? Who socketed the ECUs?
Blulude98
Post by Blulude98 »
what i mean is i don't get any real life readouts on Smanager but the error message is gone when i use a PRA calibration only.
Ecu was purchasd this way not sure who socketeted it.
Can you advise what calibration i can use for it or if possible create one that wont give me the error listed above?
.....also your website does say that a PPA Manual ECU can be used with Kpro so i am under the understanding a calibration should be available. correct??
Blulude98
Post by Blulude98 »
Blulude98
Post by Blulude98 »
That ECU is not supported and will not have a calibration that will work properly with it. What is the serial number that is on the K-Pro board inside the ECU?
Blulude98
Post by Blulude98 »
its kpro v4 (40593)
Can you please explain why its not supported?
The ECU is of a 02-04 Manual CRV.
The following link on your website sais it supports this type of ECU?
https://www.hondata.com/tech-rsx-ecu-reference
It has different circuitry than a US ECU and will not work in the same way. It will generate errors and is not supported.
Blulude98
Post by Blulude98 »
I dont beleive that's true as i have a PPA ecu from the states and its identical to the one in Australia.
The socketed ECU i have shown you above does work with a PNF calibration but that error ( P1607-ECU Internal circuit Malfunction) keeps coming up.
Is there a way i can clear this error from not appearing?
Please advise?
The circuitry is different and it is not compatible.
pmay8452
Post by pmay8452 »
Can you elaborate on this? I'm reading that kpro is available on crv 02-04 ecu.
What is the full part number of the ECU you are referring to?
