P0136
chris2000
P0136
Post by chris2000 »
FK8R with full exhaust.
Flashpro tuned. When driven on the road it does not have any check light. But when it hits the track, after a few laps it will trigger the check light on the same corner which is lift off throttle, trail braking into a long the corner then the check light pops up P0136 : O2 Sensor Circuit Malfunction Bank 1 Sensor 2.
What is causing this?? Is it because of the exhaust design or the defouler design causing the light?
Any possibility of Hondata to have an option to delete this CEL permanently?
Chris
Re: P0136
We have added this for the next release.
leechihfei
Re: P0136
Post by leechihfei »
Hi Hondata,
I'm still having this problem.
I've a catfree exhaust, PRL intercooler, and an Hondata Flashpro updated just on 7th March 2019 (with latest version).
I've also checked the box for this P0136 omission.
I notice when driven hard, I get it. If not, I don't get it.
I'm on a 12 day 5500km, road trip. So have been able to see the triggers (60% through).
I clear it with an OBD Bluetooth, stay fine till my next fuel stop. Top up gas, and it (P0136) comes back on within the 50km or so.
Would you know why this is so?
Appreiciate the help - otherwise, awesome work guys!
leechihfei
Re: P0136
Any updates on my problem., that P0136 is still lighting up?
Re: P0136
What ECU & calibration are you using? G03 or E03?
leechihfei
Re: P0136
Sorry for the late reply. Was trying to get the info you asked me.
My ECU is a XXXXX-5BF-M03
Calibration is based off " Revision 3.00 Civic Type R FK8 US 2017, 91 octane, exhaust, intercooler, improved throttle response".
Re: P0136
Do you have both the secondary o2 and the P0136 disabled?
leechihfei
Re: P0136
Under Modifications :
I have already "Disabled the secondary o2 sensor for exhaust" ,
and "Remove P0101 & P0103 error".
But how do you disable P0136?
Re: P0136
It is in the closed loop section of the calibration window.
leechihfei
Re: P0136
Hi Spunkster,
Thank you for your inputs.
I had the the box still checked...... will UNCHECK it. Thank you guys!
jHobz
Re: P0136
Post by jHobz »
Same problem here during track day. I'm having a constant P0136 error code every run I did. But nothing in my normal driving. I also noticed the next day, I only have 50kms left in my gas tank then when I hit the rev limiter from 2nd gear to 3rd gear the pop pop from exhaust is just 2x compare to 4x during track day.
SuperBike_Jake_FK8
Re: P0136
Post by SuperBike_Jake_FK8 »
So I have a 2019 ctr with full bolt ons and got the flash pro to get rid of that p0136 and p0140 codes so I paid for jail break and flashed it once I bought flash pro that is. But now the light came back up and now Bluetooth on phone won’t clear code and why does it pop up if I have boxes checked ? Or do the boxes need to be unchecked ?
Re: P0136
Please start your own thread and post the calibration as well as a datalog showing the issue.
SuperBike_Jake_FK8
Re: P0136
How u fix ?
