Kicks in when no wheel spin
Pantelis
Post by Pantelis »
I have a TC installed on my KPro 3. It works fine as TC but the problem is caused when it kicks in when it should not be. Randomly when accelerating it may kick in for a second and then let the engine rev. It even happened at idle. when I turn the TC off problem solved. i believe its a setup issue. Can you help?
Re: Kicks in when no wheel spin
How about sending us the TC calibration and a datalog from both the TC unit and KPro showing the problem?
Pantelis
Post by Pantelis »
I will do as soon as I take the car out on track again, thanks. How do I send you info?
attach the files here
