How to remove speed limiter?
crluver123
Post by crluver123 »
Is there any way to remove the speed limiter?
The current value in my map is 158mph. If I type any lower number, it works. If I type any number higher than 158, it reverts back to 158.
Is there any way to increase it above 158mph, ore remove the limiter completely?
Yes my car is capable of over 158mph, and hitting the limiter at that speed is scary as hell
Re: How to remove speed limiter?
If you set it to 158mph then it will be disabled.
crluver123
thank you
