Rev limit actuated @ 3700 rpm
radave
Post by radave »
We have a problem with stock engine on itbs which wont rev past 3700 rpm it shows a fault code 4 engine speed sensor ,we have changed the distributor and checked the wiring with no luck
Please find attached calibration and log file
i would be grateful if anyone has some advise
Thanks Dave
Re: Rev limit actuated @ 3700 rpm
It is because you have a crank angle sensor error. Check the wiring and replace the distributor if necessary.
