FP Manager version 3.1.6.0: P0128 shows up when the DTC is disabled
D-Rob
Post by D-Rob »
Hello,
I have several clients that have updated calibrations using the 3.1.6.0 software and are receiving the P0128 (Coolant thermostat temperature check) DTC code despite it being disabled in the calibration for many months.
I've been explaining to said clients that they do not have a failing thermostat, and that this is a bug in the software.
Re: FP Manager version 3.1.6.0: P0128 shows up when the DTC is disabled
Can you post the calibrations that are having this issue?
D-Rob
Post by D-Rob »
I can email them, if you'd like.
support@hondata.com?
please send it as soon as possible
D-Rob
Post by D-Rob »
Calibrations were sent a few days ago, by the way.
Thank you.
D-Rob
Post by D-Rob »
I see no mention of a fix in 3.1.8.
Should I tell the clients the error is still not addressed?
D-Rob
Post by D-Rob »
I'd like to add that 2007 RDX also tosses P0128 when the second ECT sensor is disabled.
please post the calibrations here as nothing has been received.
D-Rob
Post by D-Rob »
An email was sent to support@hondata.com on Friday, October 26th that contained four calibrations.
It has been resent just now.
D-Rob
Post by D-Rob »
Should I resent these to a different email?
Our software engineer is looking into this, but it may be a month or so before we are able to test in a vehicle.
ruddyrid
Post by ruddyrid »
Any update on this? Sucks to have to clear the code so often or having to deal with it coming on. Hopefully it's a simple enough fix
/ruddyrid
Kevvo21
Post by Kevvo21 »
Any updates?
I've had my coolant thermostat + coolant replaced, yet P0128 still pops up after 2 cold engine start cycles. Car idles fine, coolant temps are fine, not sure exactly why I'm getting this code. I've updated to the most recent update and re-uploaded my tune. I heard disconnecting my battery for an hour might help but i doubt it.
What vehicle? Are you using ECT2 for an input?
Kevvo21
Post by Kevvo21 »
Hondata wrote: Mon Jun 24, 2019 9:55 am What vehicle? Are you using ECT2 for an input?
2014 civic si.
Tuner has my 'Second ECT sensor" disabled under the 'Misc' section, is that what's causing the issue?
I can disable 'Coolant Thermostat temp check (P0128) in 'Misc', but I wanted to leave that as a last resort. Since I just replaced my thermostat, I can disable that without having the worry that my thermostat was busted.
I can email you my calibration
Thanks,
