Closed loop parameter settings
K20remix
Post by K20remix »
Hi , nice to join in the forum and I'm new to Hondata flaspro which it is current running on my k20 engine.
Just would like to understand more on Hondata which I am unclear in the closed loop setting.
Hope I can get guidance from all the pro here.
My setting current is using by default TPS WOT, but not Map Determination for WOT.
Can all the pro advice me that, (question refer to the picture numbering)
1. Is the closed loop target defines minium target lambda value?
2. Is the closed loop target lambda limit define maximum of the lambda value over ECT?
3. Is this define the target lambda target under low load? What is the low load? what is the low load refering to?
4. Is this define the target lambda target under high load? What is the high load? what is the low load refering to?
Re: Closed loop parameter settings
1 is not a limit, it is the target value
2 is the limit for that ECT value
Have you read the help file at: https://www.hondata.com/help/flashpro/c ... sub=lambda
K20remix
Post by K20remix »
Understood.
If say the target value was set at 14.30, does this mean that the ecu will control F.trim not lesser or highet than 14.30?
And if the ECT was set 14.6 at 80 degree C, does that mean that any temp on 80 or above, the ecu will control AFR not above or lower 14.6?
Thanks for the guidance
K20remix
Post by K20remix »
After reading your reply, I have created a table as the image attached.
I set slight leaner cruising from the value 14.3 got from my wideband .
Refer to my image, I would likw to know am I correct?
Hope to have guidance and thanks alot
Fuel trim is separate form the target. The fuel trim will be adjusted to meet the target.
Any temp higher than that will target the last value in the table.
