s300 Lambda overlay blank HELP
g0sammo
Post by g0sammo »
So my lambda overlay is blank when dataloging. The cells are highlighting and following the map, but the AFR values do not populate. I have checked the settings in options, and tried both the sensor overlay 1, lambda, and tried sensor overlay 2, set to sensor AF. I have an AEM wideband wired to D14, and if i pull up the sensor list, the o2 sensor shows the correct voltage from the wideband. Also if i open the app on my phone through bluetooth, it displays the AFR correctly. Any help is greatly appreciated!!!!
humble tune plus mods 10-23.skl
g0sammo
Re: s300 Lambda overlay blank HELP
Post by g0sammo »
This is in my 97 civic with turbo d16y7 with p28 ecu
attach a datalog showing the issue
g0sammo
Post by g0sammo »
hope ive done this right lol.....
It is reading ok here. IF restarting your laptop does not allow it to be seen properly, then go to the options, settings and make sure that you have the lambda overlay settings such that the conditions are being met.
g0sammo
Post by g0sammo »
Thanks Spunkster! I had tried shutting down and turning back on, but apparently thats different than doing a restart on the laptop. That worked for me and everything now displays correctly!
