Injector Size downgrade: 550cc to 410cc
ecronic
Post by ecronic »
Hi All
I've recently purchased grams 550cc injectors. I wanted to know if I can set flashpro to utilise only 410cc instead of 550cc.
Thanks & Regards
Ecronic
Re: Injector Size downgrade: 550cc to 410cc
Yes you can change the injector size to whatever you are using.
ecronic
Post by ecronic »
Spunkster wrote: Thu Nov 01, 2018 9:19 am Yes you can change the injector size to whatever you are using.
Thank you for your reply.
What I meant was, using 550cc but would like to setup in Flashpro as 410cc. Is that possible? If so, what parameters should I be changing to achieve this?
Thanks & Regards
Ecronic
You need to put in the correct size of the injector you are using. You must also enter the correct dead times for the injectors you are using.
ecronic
Post by ecronic »
Spunkster wrote: Thu Nov 01, 2018 12:19 pm You need to put in the correct size of the injector you are using. You must also enter the correct dead times for the injectors you are using.
Understood! Thanks again!
Thanks & Regards
Ecronic
