2015 CIVIC SI BASEMAP
SI RICO
Post by SI RICO »
Hi so I hate to ask but I would like to get a basemap for my current mods on my vehicle so I can atleast drive my car to my tuner next weekend on my day off. The base map I currently have loaded is the CAI, RBC MANIFOLD, FULL EXHAUST. I did mess with it a little bit to try and get my car to idle decently to fix my idle hunt and drive without it jerking every time I come off throttle but no luck since I lack the knowledge obviously. But I did manage to get it to idle steadly but once I press the throttle is hunts again. I checked for vacuum leaks and smoked tested system to find everything is sealed and good. I did attempt to relearn idle if that helps but throttle is really sensitive/aggressive so it was pretty much impossible. Any help will be appreciated.
Current mods:
ZDX THROTTLE BODY
PORTED RBC MANIFOLD
3.5 KTUNED SRI VELOCITY STACK
RDX INJECTORS
4BAR MAP
Re: 2015 CIVIC SI BASEMAP
You should discuss a basemap with your tuners as they will be most qualified to assist you with this.
