Max Slip target
RallyCivic
Max Slip target
Post by RallyCivic »
Hi,
I'm looking to install TCS on my rally civic. After reading the manuals I've found the slope output is 0.1v/%slip. Given the max input is 4.3 volts to ELD, this means approximately a maximum slip target of ~40%. This could be potentially lower after accounting for the voltage offset. Can anyone confirm this is the maximum amount?
Would it be possible in the future to be able to change the slope in S300 and TCS module? For the wide variety of conditions I would need up to 80 pct slip in mud/snow/ice. Base gravel would be in the 20 to 40 pct range.
RallyCivic
Re: Max Slip target
I think I've answered my own question. I missed the "overslip" unit meaning. So the input to the s300 is actual slip - slip target = over slip. So the 40% is the maximum input value for the S300 to make spark or rev limit changes too.
Re: Max Slip target
Yes, you are correct. The voltage output is based on overslip, so if your target is 80% it should be ok.
