Traction control on PNF Ecu
sergiokazoom
Post by sergiokazoom »
Hi! I have a 2004 Civic Si Ep3 running kpro v4. Turbo setup on boost by gear with the hondata boost solenoid. I want to purchase the Hondata Traction Control, but I am running a PNF ecu. If purchased and wired up, will the Traction Control be fully functionalrunning my PNF ecu?
Re: Traction control on PNF Ecu
It will work, but you cannot use a PNF based calibration. You must use a PRB based calibration for Traction Control to be available.
DC5teggi
Post by DC5teggi »
I see this is an old thread, but is the same true for a PND ECU in a base RSX? (both it working and requiring a PRB calibration)
2003 Acura RSX - K20A3
PND ECU with K-Pro v4
The PND calibrations also have traction control.
