Engine won't rev above 6000.
andylc99
Post by andylc99 »
Just setting up my first Hondata ecu.
Been through a lot of the forum to try and find all the answers I need but can not seem to resolve the problem with the engine not revving above 6000 when under load.
UK Civic EP3 Type R with TD03 turbo, 4bar MAP sensor, 550cc injectors, AEM AFR input on channel 0.
I have attached my tune and a data log, any ideas?
andylc99
Re: Engine won't rev above 6000.
Post by andylc99 »
Not sure why the data log did not download, so here it is
AREA876
Post by AREA876 »
Your wideband seems not to be functioning right base on datalog
AREA876
Post by AREA876 »
Can Hondata explain why is the s.trim -27 for such a lean A/F, 19.27 according to the analog reading.
Start by figuring out why the aftermarket wideband is not working correctly as the will probably lead to the resolution of the issue.
