Bouncing Idle K20A3 w/ K20A2 intake manifold
frostydc
Post by frostydc »
I have disabled the secondary runners through Kpro and it is bouncing idle from ~1500-2800 rpm. I put in a new throttle body gasket, intake manifold gasket, and am not finding any open vacuum lines. Tried a different map sensor and same results. I've attached a quick datalog as well as the base rsx tune I'm using. Am I missing something?
Re: Bouncing Idle K20A3 w/ K20A2 intake manifold
Have you tried cleaning the idle controller?
frostydc
Post by frostydc »
Yes I did, forgot to mention that.
You appear to still have some kind of air leak, or the idle controller is stuck.
frostydc
Post by frostydc »
The throttle plate was worn enough that it was letting air in even when closed. Sprayed the inside with Moly Lube and it sealed it up, so now it idles fine.
