Kpro4 Alternate Speed Input
AREA876
Post by AREA876 »
92 Honda Civic
Kpro: 48429
Version: 4.3.6.0
ECU: 37820-PND-A55 SN: 2063-503531
K20A3 Base Map.kal
I have a question about the alternate speed input, the Kpro4 vss input and the original vss are they both to display the same values?
Re: Kpro4 Alternate Speed Input
No they will not.
AREA876
Post by AREA876 »
Using the VSS input for the alternate speed on kpro 4 will the ECU know what gear you are in ?
I believe it will.
AREA876
Post by AREA876 »
I am having problem with my alternate speed set-up. The input works but when viewing the datalog my gear is not switching and I am also getting a VSS error.
Vehicle: 92 Honda Civic
Serial No.48439
Version:4.4.0
ECU:37820-PND-A55
Engine: JDM K20A (K20A3)
K20A3 Base Map.kal
K20A3 Base Map.kdl
What sort of transmission speed sensor is it? How did you set the pulses per distance?
AREA876
Post by AREA876 »
The sensor is getting it's reading from the gear by the final drive, I currently have the pulses maxed out at 499999 per mile and I still can't get speed to match GPS
Have you tried following the instructions listed at: https://www.hondata.com/tech-alternativ ... ngine-swap
AREA876
Post by AREA876 »
I have tried going lower with the pulse but the reading seems to get worst. At 499999 it's about 10 mph off, but I still get a VSS error
What transmission are you using?
AREA876
Post by AREA876 »
Transmission is V2M3 from a Honda Stream
Does this us a counter shaft speed sensor?
AREA876
Post by AREA876 »
No, sensor is coupled to final drive
If the speed sensor is the final drive type (not the 3rd gear sensor) then your pluses per mile should be in the 10,000 range not 500,000 range.
AREA876
Post by AREA876 »
Setting the pulse to 10,000 per mile resulted in 336 mph
K20A3 Base Map.kal
