leaning out during idle
Efreng35
Post by Efreng35 »
b18c 1050 ID injectors. turbo pump gas. car runs perfec air fuel ratios but after driving has strange leaning out spots once warm after some drive. map and log attached of idle. any help would be really appreciated
AREA876
Re: leaning out during idle
Post by AREA876 »
Did you set the injector deadtime?
What's the fuel pressure?
Efreng35
Post by Efreng35 »
Fuel pressure is 45psi yes dead times set. It doesn’t appear to be voltage related according to what I see in the log. I could be wrong
AREA876
Post by AREA876 »
I Also notice the fuel trims are removing around 12% of fuel, was the car tuned in open loop before it was set to close loop?
Efreng35
Post by Efreng35 »
Yes in open. thanks for the help btw. Ive been trying to figure this out for a while.
What wideband are you using?
Efreng35
Post by Efreng35 »
using aem 30-4110 uego
When it shows lean there is no real change in injector pulse width or to the fuel trim. This leads me to believe that there may be some other factor. perhaps you have an injector that is sticking at the low duty cycles.
Efreng35
Post by Efreng35 »
gotcha. is there a way for me to test for that ? or anything you recommend I do.
You can have the injectors tested and flowed.
Efreng35
Post by Efreng35 »
I noticed when applying electrical load it goes lean and begins to stay leaner as it warms up. But let’s say raising and lowering power windows cause it to go 16.5-17.0 afr . I read INjector dynamics does not supply correct dead times is it possible that’s the problem. Stock fuel pressure regulator Injector Dynamics 1050x injectors
AREA876
Post by AREA876 »
Try running in open loop and note the AF, is it rich or lean?
Also provide a datalog and current Calibration of the open loop operation.
Efreng35
Post by Efreng35 »
Will do. Do the dead times look ok? Open loop does same thing. I have it in closed loop to help out with the issue it’s worse in open loop
AREA876
Post by AREA876 »
Check fuel pump voltage and fuel pressure
AREA876
Post by AREA876 »
