Flash for Different Drive Modes
carlitos1206
Post by carlitos1206 »
Hello,
I acquired my Hondata and are very happy with the results
I have one question,
- How can I reflash in separate drive modes???
For Example: I would like to flash a Custon calibration in +R mode, Keep 91 oct in sport and keep OEM calibration in comfort mode???
Please let me know if possible
Thank you
Carlos
Re: Flash for Different Drive Modes
That is not possible. You have the same tuning in all modes, but you can change the torque requests in each mode.
carlitos1206
Based on the launch video you made you mentioned it was possible to adjust map by each mode ... or did I misunderstand???
Or maybe different consideration after your reply
Can I use OEM torque request in comfort mode and 91 Oct in sport and custom in +R????
This way I should be able to achieve my intention right???
Thank you for your quick reply
Carlos
In sport an R mode you can change the torque request, but increasing the torque request in comfort mode will usually have undesirable effects. You cannot change the fuel tuning based on the mode. If you look at the software it should be more clear how you can adjust this in the throttle settings.
