s300 standard in p72jdm la conecte y demas
deivir123
Post by deivir123 »
arranca pero no me lee parametros y demas
deivir123
Re: s300 standard in p72jdm la conecte y demas
Post by deivir123 »
hi im soldier hc373 remove j4
conversion cable cn2 for ecu jdm p72 003 in s300 standard
car start good is problem no view parameter time real
datalog is ok parameter 0 no parameter lee
You cannot use a regular s300 in a JDM ECU. You must use the s300j.
deivir123
Post by deivir123 »
ok I connect the pins cn2 with cable because it does not fit in the usdm should work so passing 4 wires do not? I soldered the 4 wires to cn2
