2018 Accord 2.0 Sport ==> Stage 1-2 question
AndyEckel
Post by AndyEckel »
Hi -
I’m new to this forum and a have a stock 2018 Honda Accord 2.0 Sport with the 10 spd automatic. I’m keen to purchase the FlashPro and dial up the performance a bit with a “Stage 1” and/or Stage 2 calibration but have been unable to determine the answer to this particular question.
Can the FlashPro calibrate the ECU such that it is programmed as follows:
1) Econ Mode (leave as is - never used anyway)
2) Normal Mode (I.e., nether Econ or Sport specified) = STAGE 1 map
3) Sport Mode = STAGE 2 map
I spend most of my everyday driving in Normal Mode and my logic is that Stage 1 makes perfect sense. A little more power than stock, but safe and reliable. When I want an extra boost, select Sport Mode and Stage 2 kicks in.
IS THIS EVEN POSSIBLE? Appreciate any insight here. Thanks!
Re: 2018 Accord 2.0 Sport ==> Stage 1-2 question
The short answer is no, since most of the tables we change as independent of mode. You'd have to run either stage 1 or stage 2.
amurciano
Post by amurciano »
Is this still the case, any recent updates to have this feature?
