launch control settings and rev limit
Hermanmax88
Post by Hermanmax88 »
When setting launch control ign retard and fuel enrichment, do those settings apply to the other rev limits? For example; if my launch control is set 4k rpm with -20 deg timing and 100 fuel enrichment, will i get the same timing retard and fuel enrichment at my 8600rpm rev limit? What about with full throttle shift?
Re: launch control settings and rev limit
No it is only for the launch control.
Hermanmax88
Ok so the reason i ask is because my full thottle shift seems to be doing something weird. I have it set to 6k rpm and when i engage it seems to cut rpm completely. It definitely works because it does cut power but It doesn’t bounce off of 6k rpm like it should. Could this be because i am using a fuel and ignition cut? Should I switch to fuel cut only? In your opinion which works best; fuel and ign cut or fuel only?
Post your calibration and a datalog showing the issue.
