Boost cut and other issues with PSI and bar conversation s
Thatbitterlemon
Post by Thatbitterlemon »
Bar and psi are not being converted correctly not sure what the software uses as face value but in two places maybe more psi and bar are not converting correctly.
I have 1.4bar set as my boost cut and it's cutting at 5.6psi if you go to boost cut in the software and but in a value in bar then use the drop down to change it psi I should comvert it but it's converting it incorrectly.
Re: Boost cut and other issues with PSI and bar conversation s
Can you please be more specific and include what vehicle this is and post your calibration as well as datalogs showing the issue.
BTW 1.4 bar absolute = 5.9 psi relative which is close to 5.6 psi.
Thatbitterlemon
Apologizes i have been busy not had chance to explain better,
Setting Boost Cut to.. 1.6 Bar have Bar as preferred pressure unit in settings..
1 bar should = 14.50 psi ?
See here after changing the drop down to psi its converted it to 8.51 Psi?
Problem i faced was PSI boost cut was set originally to 18psi (Expecting 18 psi to be boost cut but it want i over boosted hit 1.7 bar on my gauge before i realized.. ) based on this finding i can image the reason why i didnt boost cut was due to it being set as 2.25 bar in reality.. a figure i will never see with set up.
Bar is absolute and psi is relative. What do you want the boost cut to be?
