Kpro v4 Analog input problem
Garrett_si
Post by Garrett_si »
Hi, I have a K24 engine, I use a AEM 0-150psi pressure sensor on input Analog 0
The display in psi was working a few week ago when I calibrate it, but now I see over 800psi in the display.
I verify the input voltage but changing the Sensor setting from Pressure to Raw voltage, and input voltage still fine.
I attached files and calibration + screen shot
Garrett_si
Re: Kpro v4 Analog input problem
Here is the files and screen shots
Post datalogs that show the issue. Screenshots are not enough.
Garrett_si
Here is the datalog file
That is your calibration and not a datalog.
Garrett_si
sorry
here is the log
Garrett_si
here is the log
Garrett_si
Did you see something wrong?
What oil pressure sensor are you using?
Can you post a Datalog that shows the raw voltage?
Garrett_si
Sensor is honeywell 0-150psi
Raw voltage could be seen is Hondata software allow it like other standalone I think it's a necessity
