BBG solenoid frequency reccomended for bigger WG (60mm)
oksdesigns
Post by oksdesigns »
What is the best way to go about finding the best BBG frequency for bigger single wastegate setups?
My setup is a b18c1 84mm
Borg warner 62mm
60mm wastegate
Re: BBG solenoid frequency reccomended for bigger WG (60mm)
IT is trial and error to see what gives you the best performance and range with your setup.
crluver123
Post by crluver123 »
The operating range of MAC solenoids is 30hz-60hz. Why Hondata uses 78hz as the default is beyond me.
I usually change it to 45hz, do a pull, then try 35z and 55hz and see what it does. Whichever works best is where I leave it. 45hz seems to be the best though for 90% of the setups I've tuned with all different wg sizes/brands and various hose configurations.
