S300 v3 and Aem uego
Alistair206
Post by Alistair206 »
Hi hopefully I’ve posted this in the right section
So I’ve finally installed my s300v3 p28 I’ve had my wideband running for a few months and it’s been reading correctly but as soon as I swapped from my stock p28 into the Hondata p28 the readings on the gauge itself have gone well out of spec
I later pinned it’s white 0-5 volt wire into d14 and on the live data it’s showing a afr of 18 but the gauge itself is reading 11, if I return the stock ecu back into the car it returns a reading of 15 on the gauge, I’ve tapped the power and the earth for the wideband off the ecu’s power and earth for reference
I’ve spend about 4 hours looking for answers but not found much of any use so I was wondering if anyone else has had a similar issue?
tolyan
Re: S300 v3 and Aem uego
Post by tolyan »
datalog write and download here
TTR
Post by TTR »
What AEM wideband?
skaterguy1986
Post by skaterguy1986 »
Need to know where you've placed the power and ground wires as well as probably posting the calibration since some of the settings are likely not right.
