1999 civic VTI ( Si ) E.U. + S300 + OBD2 adapter
patrice
Post by patrice »
Hi,
I buy an adapter for 3 pins ( connector OEM in E.U., not OBD2 standard plug ) to OBD2 plug.
And i try to connect it a OBD2 adapter bluetooth and this don't connect with the ECU ( S300 ? )
I yet to use the app for my smartphone and it's turn on good !
But i would to put a little display with cable plug on the 3 pins / OBD2 adapter, so i must to modify the adapter and connect with the CAN of the S300 ?
i think with S300 the 3 pins OEM diag does not work ?!
thanks
Re: 1999 civic VTI ( Si ) E.U. + S300 + OBD2 adapter
The s300 only works in an OBD1 ECU and will not be able to communicate with any OBD2 devices.
