VTC tuning without a dyno
schaffertnathan
Post by schaffertnathan »
I have fuel and ignition tuned for each cam angle, but what would be the best way to tune the VTC angle maps without a dyno?
And also, if cam angles aren't optimized, would that cause MAP pressure to decrease and not be near 0. Manifold pressure at full throttle usually shows between -0.7 and -1.4
I have 2012 Civic Si, with SRI intake, 2.75" catback, 550cc injectors, E85. Also running AFR guage instead of primary O2 sensor
Re: VTC tuning without a dyno
You really need a dyno to be able to measure the power in order to tune this correctly.
