Lambda overlay not showing readings
WizardKing
Post by WizardKing »
Hi all,
I recently got an s300 v3. I have a D16z6 and I am trying get the lambda overlay working.
I am using an Innovate MTX-L Plus AFR gauge. This is hooked up to pin D14 and judging by the display sensor read out is working as it should. I don't think I have missed a setting, I did a search and tried the suggested solutions such as restarting the PC etc but still no joy.
I have uploaded a screen capture to Youtube, the o2 V reads 0 for a few seconds as it is still "heating". I cycle through the settings to show what I have it set to.
https://youtu.be/R-c3Y58yTWw
Any assistance would be greatly appreciated.
Thanks.
Re: Lambda overlay not showing readings
You should use one of the other inputs such as the ELD input D10 as D14 cannot read the full voltage range.
dan_t
Post by dan_t »
I too am having issues with the Lambda Overlay feature. I am using current software that I just downloaded today.
My particular issue is that I'm not able to get any real-time overlay data. I found a work around by recording a log, going to settings, sensor overlay, click OK and the tables populate. At that point I delete the log and start recording a new log, I then have to open settings, sensor overlay and just click OK again, once again it will repopulate the tables.
I'm not making any changes when I do go to the settings tab, just clicking OK. I don't see anything on the overlay page that would be causing it, thresholds are very wide (stock).
When recording the table trace works - shows what cell I'm in etc but the tables are all blank.
S300, K20B, 2.6.8 I believe.
Post your calibration and a Datalog showing the issue.
dan_t
Post by dan_t »
Updated to 2.7.1.0 and same issue - map and log attached
They are working here. When was the last time you rebooted the laptop? Also check your overlay settings to make sure that the conditions are being met.
dan_t
Post by dan_t »
It's installed on my work tuning laptop, It's probably been a few months since it's been rebooted but I can give that
try.
Were you able to simulate real-time data to populate the tables?
If it has been several months since it has been rebooted, then do that first.
