Lambda Reader / AF Ratio Wideband
linkdeezie
Post by linkdeezie »
Can the s300 be used with the Glowshift 7 color wideband gauges and if so, what setting would have to be used?
Re: Lambda Reader / AF Ratio Wideband
As long as it has a linear 0-5 volt output it should work. You will have to enter the calibration info into the software.
