2018 civic sport hatchback 1.5t cruise control issue (M/T)
bdub
Post by bdub »
Hi, im running the +6 psi with injen SRI base tune, when engaging cruise control at highway speeds, the car starts to get confused, rpms start jerking badly. Just wondering if anyone else has had this issue and if there something in the tune that i have to tweak to solve the issue. Thanks.
Re: 2018 civic sport hatchback 1.5t cruise control issue (M/T)
Post the calibration as well a datalog showing the issue.
mak_kioy
Post by mak_kioy »
Hello, after the latest firmware i'm dealing with the same problem. When using cruise control, the car starts to accelarate and deccelarate around the desired speed. This issue is happening on the 6psi and 9psi firmware, and only happened to the latest. Before that i did not had any issues.
Returned to stock ecu and the problem wasnt there.
I'm attaching a datalog from today and waiting for an update.
Is it safe to run this firmware or should i run the stock one until we find a solution?
Thank you
I'm located in Europe if that's matter.
Can you please post your calibration as well?
mak_kioy
Post by mak_kioy »
Spunkster wrote: Mon Feb 25, 2019 11:29 am Can you please post your calibration as well?
Hello, i'm running the +6psi (without modifications-stock induction-exhaust) and i made the following changes.
Post the actual calibration you are using, not a screenshot.
