Noob clarification - stock tune
mm64
Post by mm64 »
I've got an 08 S2k. There's an equivalent stock tune in flashpro manager for 06-09, I'm not sure if the tune stayed the same for all of these years.
Is it possible to download factory base tune for storage before using one of the flashpro tunes, or is it identical to the stock "equivalent" tune in the flashpro manager?
Re: Noob clarification - stock tune
To return to stock you must go to the online menu and click on return to stock.
mm64
Post by mm64 »
Ok, so there is no file that needs to be backed up from the car before applying the first "tune" from the flashpro to the car. Is this correct?
I just want to make sure I'm not supposed to back up the factory tune prior to using the flashpro to apply a modified tune to the car.
No there is nothing special you need to do first.
