S300 w/SDash app???
dcnxero
S300 w/SDash app???
Post by dcnxero »
Ok so i have the s300 v3 computer and was looking into getting the SDash app. Ill be using either a spare phone or a tablet.
I'm wanting to perma install the android device into my dash, so I need to setup a charging system for it.I found all the cords to do it but i was woundering if I use a usb splitter to charge it and still have it plugged into the ecu, will this effect the ecu with the charger being hooked up?
I can give pics of the wire and how it will be set up.
Re: S300 w/SDash app???
It can only connect via Bluetooth, not USB, to an android app.
crluver123
Post by crluver123 »
Spunkster wrote: Mon Mar 04, 2019 10:33 am It can only connect via Bluetooth, not USB, to an android app.
this may be true for the v3, but I know it does work with v1 and v2 via a usb cable.
^for anyone curious
dcnxero
Post by dcnxero »
Thank you for the replies. I was refering to the data logger app from SDash Development.
I have a video of it working. Im also showing 3 pics of what i have, in hopes that it will help mebpaint a better picutre of my idea/question.
So I want to add in a chaginging systembfor the tablet. A 1.0 and 2.0 usb charger puts out 500mA(.5A) and I think not to sure but it should be +5v.
So I was woundering, if i added in the charger to it will that effect the hondata usb port/ecu? I dont need to burn the expensive stuff so thats were im at with that.
Sorry bout the pics being so bigbibdid this from my phone at work.so if yall can resize them for me i wouldnt mind.
dcnxero
Post by dcnxero »
Problem solved go ahead and dead this thread thank for any info that was given.
