Wideband issue
monster1632
Wideband issue
Post by monster1632 »
Trying to hook up Aem wide band to Pin A34 and Pin A44 and not having any success . Getting 3.8V as if its not seeing an input (made sure to calibrate the car to eld/ect2) not sure if the pin out is wrong or what? Any Help?
monster1632
Re: Wideband issue
Update On what i verified. Grounded the wideband to the ecu ground, Moved the ecu Ground to the head, Grounded the wide band to the battery, Powered the wideband directly to the battery, Quadrupled checked that the calibration was set with either pin when testing. The only other thing that i have on the check list is to make sure the analog out put (white wire) on my aem uego wideband is working but currently have no multi meter to check with but still same issue of a constant 3.8v with minute fluctuation as if its not seeing the input of the wideband but something else.
monster1632
Re: Wideband issue
Lastly verified that the aem analog output is working correctly
Re: Wideband issue
Are you sure you have them pinned correctly?
https://www.hondata.com/help/flashpro/e ... ectors.htm
monster1632
Re: Wideband issue
About 90% sure unless Honda changed how they count there pins out in the newer models. i could be wrong not sure i looked threw the forum and saw some people had pin counting issues but i think im straight
Re: Wideband issue
Post pictures clearly showing the connector and where it is pinned.
